Author Topic: Fastest, lightest MX-5 edition ever!  (Read 16572 times)
March 23, 2011, 04:30:26 PM
« on: March 23, 2011, 04:30:26 PM »
Φαίνεται ότι ο dimsabas ενέπνευσε την Mazda:
http://www.autocar.co.uk/News/NewsArticle.aspx?AR=256104
Fastest, lightest MX-5 ever
This GT racing version of the Mazda MX-5 is the lightest and most powerful version of the iconic roadster ever built.
The Mazda MX-5 GT will race in the Britcar MSA British Endurance Championship 2011. It has been built as “an engineering challenge to get the weight as low as possible using Mazda’s gram strategy as the inspiration”.
Mazda says every last detail of the car has been examined to see where weight can be saved, before matching the power to the weight. It weighs just 850kg and is equipped with a 2.0-litre Mazda engine tuned to produce 275bhp. The engine is mated to a six-speed a sequential paddle-shift gearbox.
The build of the car took 400 hours. Lightweight features include polycarbonate windows and carbonfibre doors, while the shell was also dipped in acid to shed another 15kg in weight.
Other upgrades include race seats, a fire extinguisher and competition alloys and steering wheel, while the rear axle, suspensions, running gear and drivetrain have all been tuned for racing.
The MX-5 GT, complete with a bespoke Spirited Green metallic paintjob, will compete in the Britcar championship for the first time at Silverstone this weekend.
Πόσο λέτε να ζυγίζει αυτό το roll cage?
March 23, 2011, 04:50:14 PMReply #1
Re: Fastest, lightest MX-5 edition ever!
« Reply #1 on: March 23, 2011, 04:50:14 PM »
Δημήτρη έχεις δουλειά ακόμα βλέπω. Έφτασε το βαρίδι nc 850 κιλά!  :o
cw παίζει?  :????:
March 23, 2011, 04:59:26 PMReply #2
« Reply #2 on: March 23, 2011, 04:59:26 PM »
Πάντως αυτό το Μιάτα θα πρέπει να είναι όνειρο στην οδήγηση με τέτοιο βάρος και ιπποδύναμη..
March 23, 2011, 05:13:14 PMReply #3
« Reply #3 on: March 23, 2011, 05:13:14 PM »
Oνειρο ειναι... 850 κιλα, 275 αλογα, 6αρι σειριακο σαζμαν... :D Μου τρεχουν τα σαλια.
Το cage Γιωργο ζυγιζει ευκολα ενα 40αρι κιλα. Της OMP για τα ΝΑ/ΝΒ που ειναι το μισο απο αυτο, ζυγιζει 27 κιλακια. ;)
March 23, 2011, 05:26:46 PMReply #4
« Reply #4 on: March 23, 2011, 05:26:46 PM »
Μαλιστα.Κανουν λογο για : "0 to 60 mph (96 km/h) takes just 3 seconds and top speed is 160 mph ( 257.5 km/h)."  :o :o
Yπεραισιοδοξο το βρισκω το 0-100 αλλα ποιος ξερει?
Αναγνωριζει καποιος τις ζαντες? Φερνουν σε OZ Ultraleggera αλλα δεν πρεπει να ειναι αυτες.
Θα τρεξει σε αγωνα αντοχης οποτε δε νομιζω να ακολουθησαν το δρομο της CSW.Επισης τα extra parts της υπερτροφοδοτησης δε θα βοηθουσαν κ το να μεινει το βαρος σε τοσο χαμηλα επιπεδα. Ισως ειναι καποια τσιταρισμενη ατμοσφαιρικη εκδοση του διλιτρου MZR με τα καλουδια της CSW. :????:
March 23, 2011, 05:48:42 PMReply #5
« Reply #5 on: March 23, 2011, 05:48:42 PM »
Δεν υπάρχουν πολλές πληροφορίες αλλά κοιτώντας τους κανονισμούς λένε ότι μπορεί να τοποθετηθεί κινητήρας από άλλο μοντέλο της εταιρείας ή να αυξηθεί ο κυβισμός αλλά δεν αναφέρει τούρμπο πουθενά:
The engine crank case and head must be original units specified for that manufacture of car but may be modified. An alternative engine from the manufacturers range may be fitted to the car but it has to be the same make of the manufacturer of the car, for example a BMW engine in a BMW M3 may only be replaced by another BMW engine.
 The cubic capacity of an engine may be modified.
Το συγκεκριμένο Μιάτα το προετοίμασε η Jota Sport.
March 23, 2011, 07:46:36 PMReply #6
« Reply #6 on: March 23, 2011, 07:46:36 PM »
Τέλειο! Πανέμορφο! Υπέροχο! Αψεγάδιαστο!
Όνειρο είναι το άτιμο, μου τρέχουν τα σάλια. Η Mazda παρουσίασε το τέλειο Miata, τελεία και παύλα! Όσο περισσότερο το κοιτάω, τόσο περισσότερο μου αρέσει. Φανταστικό! :clap: :clap: :clap: :clap: :clap:
Κάποιες απορίες: όταν λέει ότι βούτηξαν το αμάξωμα σε οξύ κι έτσι μειώθηκε το βάρος κατά 15 κιλά, τι ακριβώς εννοεί; Όχι πως θα το κάνω :llol:, απλώς θα ήθελα να ξέρω πώς λειτουργεί η ιδέα.
Επίσης, να παρατηρήσω ότι τα 850 κιλά* δεν είναι διόλου απλησίαστο για το κοτέτσι μου, αλλά όντως θα χρειαστεί λίγη δουλίτσα ακόμα. Βέβαια, το NC ξεκινά από βαρύτερη βάση, έχει βαρύτερο κλουβί, βαρύτερο μοτέρ, πίσω προφυλακτήρα... Το θέμα δεν είναι να συγκρίνω τη Mazda με μένα, αλλίμονο. Άλλωστε, το συγκεκριμένο κοστίζει πολλά χρήματα, όχι αστεία. Το θέμα είναι ότι η Mazda παρουσίασε κάτι που μας στοιχειώνει τη νύχτα και ρεφάρει με τον καλύτερο τρόπο για εκείνο το κακόγουστο ανέκδοτο. Μπράβο της και πάλι και μακάρι να κυκλοφορήσει με πινακίδες κι όχι μόνο στους αγώνες.
*Αν το βάρος είναι όντως τόσο, γιατί αν είναι αντίστοιχο του "0-60 μίλια σε 3 δευτερόλεπτα"... :zalistika: :zalistika:
March 23, 2011, 08:36:29 PMReply #7
« Reply #7 on: March 23, 2011, 08:36:29 PM »
Το μπάνιο σε οξύ αφήνει μόνο το αμάξωμα (shell) και αφαιρεί οτιδήποτε μικρό και περιττό. Χρησιμοποιείται πολύ και σε παλιές καρότσες σε περιπτώσεις ανακατασκευής.
Υποθέτω η Μάζντα Αγγλίας δεν μπορούσε να πάρει ένα τελείως γυμνό αμάξωμα από την Ιαπωνία οπότε πήραν ένα καινούργιο το ξήλωσαν όσο μπορούσαν και το βούτηξαν σε οξύ για να μην μείνει τίποτα.
(σκεφτείτε τί γαμάτο θα ήταν να είχε κάνει τα ίδια η Μάζντα στο ΝΑ! :excited:)
March 23, 2011, 09:05:46 PMReply #8
« Reply #8 on: March 23, 2011, 09:05:46 PM »
Επίσης, όταν η Mazda ετοιμάζει ένα αμάξωμα το οποίο πρέπει να είναι αρκετά στιβαρό για ένα μοντέλο 1.120 κιλών, καταλαβαίνετε ότι τα 850 κιλά τού φαίνονται αστεία. Όταν προσθέτει και τόσες ενισχύσεις, τότε το αμάξωμα έχει ακόμα πιο εύκολο ρόλο. Το βουτάει λοιπόν ολόκληρο μέσα στο οξύ κι ανάλογα το πόσο θα το αφήσει, τόσο θα οξυδωθεί. Υπολογίζει πόσο μπορεί να το αδυνατίσει χωρίς να υπάρχει αρνητική επίδραση πουθενά και το βγάζει. 15 κιλά όφελος δεν είναι καθόλου άσχημα. :exaclty: :exaclty:
March 23, 2011, 09:12:39 PMReply #9
« Reply #9 on: March 23, 2011, 09:12:39 PM »
Εγώ πιστεύω ότι τα 15 αυτά κιλά πρέπει να είναι από τα διάφορα στρώματα προστασίας του αμαξώματος κατά της σκουριάς, ελαστικές αποκαλύψεις για μόνωση και αδιαβροχοποίηση κλπ. Δεν νομίζω το οξύ να είναι τόσο ισχυρό που να τρώει μέταλλο
March 23, 2011, 09:28:37 PMReply #10
« Reply #10 on: March 23, 2011, 09:28:37 PM »
Προς dimsaba''Έχεις σκεφτεί να βγάλεις την πίσσα που έχει το αυτοκίνητο για αντισκοριακή προστασία?Το έχω ακούσει να γίνεται σε κοντράδικο αυτοκίνητο......
March 23, 2011, 09:47:18 PMReply #11
« Reply #11 on: March 23, 2011, 09:47:18 PM »
Το αυτοκινητο συμφωνα με info που βρηκα σε ενα blog ειναι 17 φορες πιο στιβαρο απο την ελαχιστη απαιτηση της FIA. :o
March 23, 2011, 10:28:37 PMReply #12
« Reply #12 on: March 23, 2011, 10:28:37 PM »
Το διάβασα, εκπληκτικό... Ελπίζω ένα μέρος από ότι έχει εφαρμοστεί σε αυτό να περάσει στο νέο ND.
Φανταστείτε ένα νέο ND με βάρος 940-950 κιλά και δύο φορές πιο άκαμπτο από το NC  O0
March 23, 2011, 10:56:17 PMReply #13
« Reply #13 on: March 23, 2011, 10:56:17 PM »
Καλά, σίγουρα αντιγράφουν το samba. Κοιτάξτε λίγο τον μονό καθαριστήρα και τους καθρέφτες
Kawasaki
March 23, 2011, 11:02:36 PMReply #14
« Reply #14 on: March 23, 2011, 11:02:36 PM »
Kawasaki
Γιατί η κεντρική κονσόλα πάει πίσω? :P
